tbe2002
- February 10, 2005
- Longmont, CO
- 08 Expedition Limited
About 2 months ago I did the front breaks on my 93 explorer. I replaced the rotors, wheel bearings and pads. When I put everything back together I did torque everything do to specs. Well last night I jacked up the front end to see if there was any movement. Holding the wheel at the 10 and 2 position it moved a little. I then stuck my head under the truck to see if I could see where it was coming from. It is not coming from ball joints or tie rod ends. I can look in the wheel and see the rotor moving as I wiggle it back and forth.
Now there is not alot of movement and I haven't noticed any driving difference. There is no uneven tire ware so far that I can see. My question is, is it normal for there to be a little movement in the rotor/ bearing?
Thanks in advance.
Thanks in advance.
