@Sharin &
@edwx - Thanks for your replies to my question.
The reason I asked what your "cold start" procedure was to establish if the the engine was warmed up to the point where the automatic transmission cooler came "into play".
Sharin, from what you've written I'd imagine that your engine is reaching operating temperature before you enter the vehicle, so I'd wager that your automatic transmission cooler that routes through your engine radiator would be operating, and thus your transmission fluid would also be up to operating temperature by the time you leave your garage. Let me go on to add that I understand that you don't feel comfortable with your Ex's behavior, especially if you're leaving a driveway, cutting across multiple lanes of traffic, while making a left hand turn.
edwx, despite the fact that your outside temps are in the 60's and 70's, given your written "cold start" procedure, I'm thinking that your transmission fluid is not up to operating temperature when you start your journey. As a test, you might try and completely warm up your engine to "normal" operating temperature before you start driving and see if that makes a difference in your transmissions' shift quality.
peterk9 - thanks for your imput - what's your cold start procedure up there in the Great White North?
Do you warm your engine up to operating temperature before your journey OR do you just turn the key and start driving?
