Hi Matt and Rob,
Thanks for your ideas...most helpful. Enclosed below is some input from blacksheep josh on the forum...sounds pretty knowledgeable. Those factory roof rack bars are easy to take off and put back on...worth it for even one MPG improvement! That 38 MPG figure may not be as wild as it sounds. That 4.0 L single overhead cam engine's reputation is not too great -- short-lived, high maintenance, but it can squeeze more miles from a gallon of fuel than the old workhorse pushrod engine that I have. I put in a new 195 degree thermostat in response to low coolant temperature...good for another small MPG increase. That Mazda 5 speed with overdrive is a great manual tranny...buttery smooth gear changes, up and down. The engine just ticks over 1600 Revs @ 55 MPH in overdrive, while turning in better than 25 MPG. My old XJ-6 Jag turns 1950 Revs at the same speed, and gets 19 MPG.
I'll check out Aldive to see how he got those astonishing miles per gallon figures with his Explorer. I looked at his 32 MPG Explorer project and got some ideas from it. He has a custom-tuned, lean-running power control module (computer), synthetic lubricants all around, and other trick stuff like indexed spark plugs, underdrive accessory drive pulleys. etc. Experiments with electrolytic HHO (hydrogen, hydrogen, oxygen) injection are also underway. Electrical energy is expended to separate the water molecule into its atoms. In a perfect closed loop, energy recovered would just equal energy expended. I suspect it's hokum, but what do I know? These measures are not for everyone, but many are effective. Why not start out with good maintenance, sensible tire pressures, low drag exterior, no more weight than necessary, and steady, moderate speed. That should enable you to beat the EPA rating of whatever you are driving.
Happy trails,
Mike Fisher
Posted to Ford Explorer Enthusiast Forum on June 15, 2008:
My Explorer is a 1999 Sport with two wheel drive and 5 speed manual transmission. It is capable of 25 miles per gallon at 55 MPH and 32 PSI tire inflation. I'm considering removing the roof rack cross bars to reduce wind resistance. Has anyone tried this? Also, I'm thinking of installing a salvage yard cruise control from an Explorer or Ranger with a 4.0 L OHV (pushrod) engine. How big a project would this be?
Thanks for your ideas,
Mike Fisher
Dear Michael Fisher,
blacksheep josh has just replied to a thread you have subscribed to entitled - Fuel Economy, Cruise Control, Roof Rack - in the New Member Forum forum of Ford Explorer Ranger Enthusiasts Serious Explorations.
This thread is located at:
http://www.explorerforum.com/forums//showthread.php?t=217980&goto=newpost
Here is the message that has just been posted:
Look up Aldive. He has a 99 SOHC V6 and hes gotten up to around 38 miles per gallon.
As for the cruise control, you should be able to install it, might take some figuring out though but I don't see why it shouldn't be possible.
I've taken off the crossbars on the roof rack, and I gained a couple miles per gallon. So it'll help.
There may also be other replies, but you will not receive any more notifications until you visit the forum again.
All the best,
Go to Previous message | Go to Next message
