You likely have a bad fuel pressure regulator. Vacuum regulates fuel pressure and the diaphragm now has a small leak. Remove vacuum hose and you will find gas. Might have evaporated by the time youchecked it. Vacuum line can be blocked off and the engine will run fine at the higher idle pressure. It may only be at a certain position it will leak. It may take a while, connect it to a tube into a container. It gets sucked into the intake manifold and goes past the piston rings or PCV valve. Fairly common problem. When I bought one for my 92 it was about $65. Easy repair, only two bolts hold it in and a flange nut for fuel return line. Mine never did auto correct the fuel mixture even after 200 miles. I had to disconnect the battery to reset the computer, then it ran great.
The other possibility is a leaking fuel injector. Regardless, the fuel line should maintain at least 25# for 15 minutes after key turned off (engine not running from key on). If it doesn't, there is definitely a fuel leak. I always remove the schrader valve when making a fuel pressure test for most accurate reading. I assume the dry line you talk about is the vacuum line and not the fuel return line.
