Fuel leak - 96 Explorer Sport | Ford Explorer Forums - Serious Explorations
Diginick
Denver, CO
1996 Ford Explorer Sport
Hello, I recently started noticing a fuel leak in my 96 Explorer Sport, which is constant when I'm driving, and stops when the car is turned off.
Got the official warning when I took it in for an oil change last week; the tech noticed and alerted me quickly, and that it is dangerous to drive until the leak is resolved.
They gave me an estimate of $250 plus labor. Notes from Meineke "FUEL LEAK FROM FUEL SUPPLY LINE, NEED TO REMOVE FUEL TANK TO VERIFY LEAK"
However, when I look under the car (driver side leak), and inspect the fuel line it looks fine. The leak is coming from something between the fuel tank and the fuel line I suspect, but I'm not sure what that piece of the engine is.. best guess maybe transfer case?
After seeing it, I don't know if they're honest in saying they would have to remove the fuel tank, and that it's the fuel line.
I doubt this is something I would fix myself, unless it's surprisingly easy, bcuz I don't have a lift at home.
I want to ask if there's a way I can better understand for myself where the leak is coming from, and what/how it needs to be fixed? So I can know what to expect at a shop.
I will post a pic later to help illustrate, as I didn't drive the car to work today after getting worried driving it. Just thought I'd start my thread now.
Any advice on how to tell more would be appreciated!
The tank does indeed need to be dropped to access the fuel supply line from fuel pump to fuel filter. If it is leaking bad enough to make you think it is coming from the transfer case do not drive it at all.
The 250 plus labor is probably to cover a fuel pump also but in your case you do not have a choice. Not easy.
Thanks for confirming, generally it sounds about right for the job.
Some areas to check for leaks are around the quick disconnect fittings at the fuel filter (right under the driver's seat in the frame rail. Looks like a small metal can) and the two fittings connecting the fuel lines to the fuel pump sending unit in the tank, which will require dropping the tank, about a 2 hour job. I've done it quite a few times, it's not complicated, but wrestling with a tank under the vehicle without a second pair of hands can be difficult.
Replacing fuel pump guide
(Note: 99-up Fuel Systems are returnless. there is only one quick disconnect on the sending unit to remove and the fuel pressure regulator is in the sending unit):
Dropping the tank requires a long 16mm for the front two bolts on the gas tank, a short 13mm, 8mm, 7mm, assorted sizes of quick disconnect tools, long extension, wobble, jack and patience. A second pair of hands is always welcome with this job.
Remove the spare. Lift the explorer and put it on jack stands as high as it will go so the tank will slide out, (put them under the frame just before the forward leaf spring perches so the axle will drop a little bit making it easier to get to the two lines on the rear of the tank.)
Remove the two filler hoses going to the rear of the tank. Loosen the hose clamps and work them off.
Put your jack under the rear of the tank to support it. Towards the middle of the tank there will be a plastic strap. it has a long 13mm bolt that is over the top of the driveshaft bolted to the frame. Use the wobble and long extension to remove it (if you want you can unbolt the driveshaft from the rear axle to get more clearance. You will need a 12 point 12mm deep socket).
(For this next step you might want to remove the driver's side rear wheel to be able to get enough clearance to get to the connections.)
Drop the tank a little bit so as to reach the plastic evap line (DO NOT drop all the way, the plastic EVAP hose will break if stretched too far.) Remove the green evap line connector by squeezing the two tabs and pulling it off. Disconnect the electrical connector to the pump.
If you can reach the quick disconnects for the fuel lines remove them now, if you can't you can drop the tank a little more, just don't put any tension on the fuel lines. There will be a lot of fuel coming out of the lines so keeps some rags handy.
Lift the tank back up to its original position to take the strain off the two bolts on the front of the tank and remove them. Drop the tank again as far as it will go (you may have to slide it off the jack to get enough clearance) and slide backwards. (depending on how much fuel is in the tank a second pair of hands on the front of the tank may be required.)
Slide the tank off the jack once the front of the tank is on the ground if you haven't already. Move the tank to the passenger side to get it off the strap, then lift the strap out of the T-slot in the drivers side frame rail and slide it and the tank out from under the explorer.
Remove the 6 8mm screws holding the fuel pump sending unit in. Remember the orientation of the fuel lines! Carefully work the sending unit out of the tank, the fuel level float will not come out with some careful maneuvering so DON'T FORCE IT. Once out make sure the sock is still attached to the pump. If not, it's probably floating in the tank and you will need to fish it out.
Loosen the hose clamp holding the fuel line to the pump and remove the electrical connector from the pump. Use the 7mm socket to remove the bolt holding the pump retaining strap in place. Slide the pump out of the sending unit.
Install is the reverse of removal. Orient the sending unit as you took it out. Don't forget to install the evap line before lifting the tank all the way up. And push the tank up as far as it will go once done to get the strap bolted back in.
Dan, thank you for the detailed instructions! I'm not sure I will try to fix this myself, unless I can get someone with a jack to help.
Although I have some pictures here, and a video I took of it today. It leaks when the engine is running only. The fuel line looks ok as far as I can tell, from looking here. Not sure what this engine component is, can you tell?
Video
Thats the forward leaf spring hanger.
You've got a leak on top of the tank. Could be the quick disconnect or a hole in the flex line or hard line.
On the upside your fuel pump is working. :thumbsup:
I would not drive that
Thanks Dan, "quick disconnect or a hole in the flex line or hard line" I'll keep that in mind. Gonna get another estimate tomorrow. I've stopped driving it until I can get it fixed, hopefully not for too much $ or I'll explore other options. And good it's not the fuel pump then!
In case anyone else is going to reply, I got it fixed at the shop already. It was a leak in the fuel line, and didn't sound like a job I'd want to try on my own! Thanks for all the help.
