Fuel Pressure Regulator problem? - FIXED | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
daydreamer
East Central Illinois
'94 XLT 4X4
I pulled the dual vacuum lines off of the EVR vacuum solenoid and gas poured out. I suspect the fuel pressure regulator is leaking gas into the vacuum lines. I have a "94 XLT with 236,000 miles. I have a couple of codes 137, 173 KOER (HO2S, L + R, sensor fault, always rich.) My question is when I replace the regulator do I have to lubricate the O-ring before installing? Can I just use a little bit of engine oil? Thanks.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
'01 Ford Ranger, RIP 93 X
do you need to know what the codes mean or do you allr eady know?
and give me a few minutes, i'll consult my haynes manual and see what it says
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
fixxxer
Aurora, Co.
93 XLT 4X4
Ford TSP says to lubricate a set of new o-rings with a light oil, they say Ford spec ESE-M2C39 or equiv. Not to use silicone grease as it will clog the injectors.
daydreamer
'94 XLT 4X4
I went ahead and changed the fuel pressure regulator. Now I am getting no codes and the check engine light is off. :)
BrooklynBay
Staff member
Moderator
Brooklyn, NY
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
I use ATF or Vaseline to lube fuel system o rings
Nice work!
phntmfoot
'95 4door Eddie Bauer
What problem were you experiencing to cause you to replace this? I have a fuel pump that runs continuously and its been replaced and has the same problem. I dont have a clue what to do from here but it wont start for me to take it somehwere to get looked at.
