Bix
- April 16, 2013
- Edmonton
- 91 X xlt
I have been having some issues with throttle and gas, and was wondering if my fuel pressure regulator was to blame. I hooked up my fuel pressure gauge to the shrader valve and got out the trusty haynes manual. It states that normal pressure should be between 30-45. It was around 32 when i tested it. Since the gap is so large inbetween the 30-45 where as my old blazer needed 60 on the dot and nothing over or between i was wondering if my regulator is starting to go since its getting close to 30 or if a brand new regulator would also read from 30-45? has anyone replaced it and seen a 40-45 reading ?
i dont know what else would cause the fluctuation between 30-45 but the regulator since im pretty sure my fuel pump is working well.
Thanks for info anyone has on this issue
