Fuel pressure too high? Pressure Regulator?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
If harbor freight gauge is showing 65 psi at idle, is my filter in need of change? Others online have reported 65 psi as well at idle. It took about an hour last night to drop to 40 psi.
That's a great pressure, anything under 60psi is a worry with a 99+ Ford. Change the filter, if it's not known how old it is, it's time.
koda2000
x
65 PSI of fuel pressure is about as good as it gets. That's not your problem.
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
So why negative trim on long term?
So no way my filter needs changing if I have good psi pressure?
I don't know what previous owner has had done.
No real issues, just seeing -9 and -9 at idle on ltft.
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
Fuel rail 65 at idle
O2 b2s2 0.815
O2b2s1 0.090 volts
O2b1s2 0.045
O2b1s1. 0.820
Stft b1 1.6
Ltft b1 -11.7
Stft b2 0
Ltft b2 -9.4
@ idle , my negative ltft drop as rpm goes up like one is -6 @ higher rpms
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
Pcv valve would rattle sometimes when I shake it. AUTOZONE 5.50, FORD WANTS 25.00
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
koda2000
x
The PCV should rattle every time you shake it.
koda2000
x
Does the 2003 ST still have the PCV valve twist-in on the rear of the DS valve cover? Does it also still have the coolant line as part of the PCV valve? If the '03 still uses this weird PCV valve I don't see how AZ sells it for $5.50. I think I paid around $11.xx for mine at Advance. RockAuto currently shows the Motorcraft for $9.58 (plus shipping).
Note: RockAuto shows 3 different style PCV valves for the '03 ST.
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
Mine is not heated but is on back of engine drivers side and turn counter clock wise to remove
koda2000
x
koda2000
x
Question - If you stick a finger inside your exhaust tip does it come out black and sooty? If it does I'd be thinking upstream O2 sensors. If you've said you've replaced them already I may have missed it. Heated O2 sensors are designed to last around 120,000 miles and in my experience do not always throw codes when they are no longer working correctly. This will effect your fuel trims and fuel economy.
The downstream O2 sensors just monitor the cat efficiency and have no effect on how the engine runs.
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
Negative ltft, my stp air filter has less than 9000 miles, and I don't live on or normally drive a dirt road.
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
Changed air filter, pcv, at first it appeared it dropped w numbers (example neg 10 went to negative 8)..I drove 30 miles one way and back and the numbers are almost identical. 8 don't know if it takes awhile for ltft to calculate.
Floridaexplorer43
Tallahassee, FL
2003 4wd 4 0
65 or 64 psi on fuel rail dropped to 60 pretty quick after turning off and was 35 psi about 2 hours later.
Tried spraying carb cleaner this morning for leak didn't notice anything.
Code p2195 set check engine light
