explorerscope
- December 25, 2004
- Deland, Florida
- 1993 explorer 4D 4x4 auto
Ok here is the thing. My 93 explorer stall a few weeks ago. I had someone working on it and he discovered water was in the gas tank and fuel filter. The filter was changed and gas tank cleaned out. He put back on the tank and the truck was running for about 10 mins or so then it cut off. Later on he called and stated the float was not put in correctly on the fuel pump. I confirmed this because the fuel guage reads way above full when there was only a few gallons of gas in the tank when he put it back in place.
We thought maybe he did not put enough gas so I put about 7 more gallons and it still did not start. Will not having the float on properly cause the vehicle not to start or did some connection jump loose? I am not hearing the fuel pump engage when the switch is in ON position, I swapped the relay and i still don't hear nothing.
Right now, I'm so po (no moneyto afford a mechanic) and I'm thinking of dropping the gas tank to see if I can find the problem myself and possible put the float back in correct position. So far, I've drained the gas tank. Do you think I need a new pump or should just correcting the float solve the problem? I knows nothing much about cars, but I got a service manual and learn fast and I think I can do this, so how hard a task do I got?
Note: before working on the gas tank it ran on 87 regular grade unlead and he said he put in 89 midgrade unlead will make it work better, is this also a problem?
