should be right under the fuse panel under the hood onthe passenger side. remove the fuse panel (should slide up once you push back the 2 tabs holding it in) then there should be another box that's the same size as the fuse panel, take that out the same way and the relays are on the bottom side of that...beleive it's the one closest to the firewall but not 100% on that one.
