EB4X
- December 28, 2016
- Orange county, Ca
- 95 Explorer 4X 4.0 ohv
Hey gang,
Thought I'd post this for anyone interested....I'm not sure if the 97 is in same spot (most likely since same back hatch/ setup) but sure 98 and up are a few inches further back and to the left a hair --and more troublesome due to metal contour. (The part numbers for a 95 versus a 96 gas tank are DIFFERENT...but pump falls EXACTLY at some spot ...as expected.)
Anyway, here's some pics...couple with notes...
Will probably post after pics of custom cover panel once pump arrives --might clean up / file back cut too. The back area/ cut before upward slant becomes a double layer hence semi sloppy cut --- my cheapo metal nibbler couldn't handle double layer -- would recommend using beefier/thicker cut range if had to do again --though this cheapo one worked like a champ for 80% of job.... didn't go over small rib though either. (Only $11.49 on Ebay - free ship) Had to cut Sawzall / reciprocating saw blade down to about a 1 1/2" length (for safety) to tackle challenging spots. (Stupid blades wouldn't stay in jig saw...otherwise that would've been great option)
