Hyper26414
- July 22, 2007
- St. Louis, MO
- 5.0L 98 XLT
Can you recommend a fuel pump for my '98 5.0 explorer mods are listed in my signature.
That depends on your right foot!
The PCM will control fuel flow based on the amount of air entering the engine so (and i,m no expert) it should,nt matter if you have a high flow pump since it will control flow based on your engines air intake requirements to keep a safe air/fuel ratio under all rpms and loads.
Simple answer is no.
Do you have custom tunes loaded on your Livewire? If so the tuner has already made the necessary adjustments for air and fuel and the Livewire doesnt know what size fuel pump you have.
All my tunes are for street or towing performance. My mileage didnt get better or worse. Performance got better but at a price since now I have to run premium fuel, so thats where it hits the pocket book.
Will this ford racing pump be a direct fit? What kind of fabrication would have to be performed if not? Where should I purchase it? I don't really want to buy it online if I will have issues installing it. I just want to make sure it says it is for 86-97 mustangs.
no farbrication will be needed as you won't be getting everything in that picture. You'll just be getting the pump itself, and will have to splice it in. Really not that hard.
