Scott385
- June 17, 2009
- Menomonie, Wi
- early 90s
94 4.0 Exploder. When I dropped the fuel tank the fittings ontop of the tank were rusted bad and cracked. I cut the back end of the vehicle off since it was jacked up anyways and am making an offroad rig. I've got tons of room and can mount any tank I want now. BUT...got a question about the fuel pressure. From searching I found stock is about 60psi at the fuel rail....correct? As long as I get a tank/pump from another vehicle that also needs about 60psi I should be good?? My dads got a bunch of older cars but most don't use that high of pressure (30ish), so they wouldn't work....?? And don't say go buy another pump as that won't work as the metal piece in the tank is also rusted to nothing :thumbdwn:
And a pic so you can shake your head and say wtf
