Fuel Pump Relay | Ford Explorer Forums - Serious Explorations
Fuel Pump Relay
aloiscious44
oyster bay NY
Explorers: 95 XLT, 06 EB
I'm getting an erratic signal to the Fuel pump relay upon starting my 95 Explorer. Most times it pulls in, some times it doesn't. I installed a new relay, which worked consistently for a while, but now it is starting to get erratic again. Anybody have a scematic on the circuit? where is the signal coming from before the relay?
Sounds like you may have a bad connection on the relay connector. Can you pull the relay out of the connector easily or does it take some effort? I would look at the connector first to make sure its not the issue.
