Fuel Rail Pressure Sensor Location | Ford Explorer Forums - Serious Explorations
timmyt101
Phoenix AZ
2007 Ford Explorer
Can someone please tell me where the fuel rail pressure sensor is on a 2007 Explorer with the 4.6L V8? Thanks.
Location is on the fuel rail near injector # 6. Vacuum hose connection on one end, electrical connector on other end.
2 bolts secure it to the fuel rail.
Thank Bill. Sensor replaced and the Explorer is running great.
Can you share what problems you were experiencing? May help someone if this thread comes up in a search.
Running rough and hard start. Check engine light came on. Caught a P0193 code. Battery, fuel level, fuel pump, wiring all check out. Only 12,000 on fuel filter. Sensor was next - was not reading correct voltage. Replaced and all good.
Having the same codes but no symptoms yet. I replaced my fuel sensor and fuel filter but no luck. How do you go about checking the fuel pump?
