Shondue
- November 20, 2002
- Somerset, KY
- 93 XLT 4x4
I came home from work last night and the explorer wouldn't start, so when I opened the hood and turned on the key I could see fuel shooting about 18" out of the intake area towards the passenger fender. The local autozone folks seemed to all think that it was the pressure regulator. Original post
a pressure regulator leaking like that. Sounds more like a fuel injector hose connection. FPR is in that side and only mounts with 2 bolts, screw off the return line, and slide off the vacuum line. Shouldn't take more than 10 minutes and about $60. I'd verify where the gas is coming from first and use some safety glasses! Maximum pressure is 39#. Opera House
Now the leak was the line off the lower section of the regulator. Replaced the line reducer with a new one. The X still acts like it is flooded Bad!! What does the lower line do? How much presure should be on it? Is the regulator still bad?? Please help
