jenglish007
- November 26, 2006
- centerville,l tn
long time reader first time poster, I have read all the threads i can find on the fuel relay and fuel pump problems but I have a simple question for all you ford guru's that seem to have most of the answers, First of all my fuel pump will not prime, i checked the voltage on the inertia switch, it is good. I checked all my connections at the relays they are good, but when I bypass the fuel relay the pump seems to be priming or running (i can take the gas cap off and hear what sounds to be a sloshing sound). Does this mean the relay is bad? and if so do i need to go ahead and replace the eec relay (i do not now how to test or bypass it)? If i jumper across the fuel relay would the engine start? I just finished replacing all the upper gaskets in the engine, now i am not getting any fuel pressure or power to the pump unless i jumper the fuel relay. Any help would be appreciated.
