mellie
- June 1, 2004
- McAlester, OK
- 1994 Explorer 4WD XLT
I have a problem with my '94 Explorer. I am having a problem with starting it. I can drive for about a week with no problem, but then I get stuck somewhere because it won't start. The only way we can get it to start is spraying starter fluid in it. That worked for a few times, now it won't start at all. We tried the starter fluid one more time and got it to idle on its own but when I tried to push the gas pedal, it died. we got it started again and it would accelerate by manually spraying starter fluid into the throttle body, bypassing the air intake. when we put the air intake back in place, it died. I have taken it to a mechanic, but it never does the same thing to him. He fixed vacuum leaks and advanced the timing, replaced the air cleaner and fuel filter. It ran great for about three weeks then started again. Now it won't run at all. HELP! The only thing the mechanic can tell me is that it could possibly be the fuel/ oxygen ratio?
Thanks,
Mellie
Thanks,
Mellie
