JSWarrell
- April 12, 2021
- Levittown, PA
- 1994 Explorer XLT
So this is more of a "How I did it" rather than a How-to, but I decided to fully document my repair as I found no info on this before. I don't know how helpful this will be for 91-92 owners, but I'm guessing the only real difference in the systems is that the vapor canister is in a slightly different location. This repair was done on a 1994 model.
Ever since I bought my Explorer I would smell gas after a long trip. Upon one the many discoveries I make while performing other services and repairs to the truck, I found a very rusty 1/4" line running parallel to the fuel lines, with many holes in it. That is the fuel vapor line.
My state and county requires that this vehicle passes both safety and emissions inspection. Somehow it still passes emissions with this problem, but I think it's because all they care about at the shop I go to is that the check engine light is off, the fuel cap doesn't leak, and it passes the dyno pipe sniffer test. EEC-IV doesn't monitor EVAP performance, only the canister purge circuit, so the check engine light doesn't come on like it would for an OBDII vehicle.
Anyway, I put this task off because I knew it would take me longer than a day to do, including any unexpected problems I might encounter along the way. In reality, this shouldn't take longer than a day to do, but I get very opportunistic and like to address things while I have something apart that I wouldn't be able to get to otherwise.
So....pictures.
Day 1
These three along the frame are the fuel lines. The pressure and return fuel lines are stainless steel and don't have this problem. The vapor line appears to be plain old steel. I imagine at one point it was zinc plated or something like that, but not anymore.
Dropping the tank...I made sure I was on E with only a couple gallons left in the tank, pretty much just enough to run to the cheapest station in my town.
This skid plate has to come off first. There's three bolts in the front:
One bolt in the frame rail just above the leaf spring. This one was a pain even with wobble extensions on my impact wrench. The parking brake cable runs through this space so you have to hold that out of the way as well:
And one towards the rear beside the driveshaft:
(These are all 13mm)
I had a jack with a piece of 4x4 lumber ready to catch it. The plate is a bit on the heavy side so having that thing drop down can be a bit surprising if you're in the way.
The front of the skid plate will pivot and can then be slid out by the center tab.
I later found that the corner piece of heat shield was removable and needed to be removed so that the front strap could be completely undone. I neglected to PB blast the two studs along the rearward edge and ended up breaking one of them.
A little bit of wiggling and tilting and it came right off. I'll be wire brushing this and spraying it with some rust converter.
All that's left holding the tank is a single strap right in the center. I had a jack ready to catch it and undid the strap.
Wondering why it was getting snagged, I forgot about the filler neck and vent hose. A 5/16 driver with some extensions and a large pick and they popped right off.
And there's the lines connecting to the tank. The small one making the "S' curve is the vapor hose, connected to the hard line along the frame. I also took this opportunity to remove the brake line that was bypassed by a previous owner and just left there. Inspectors didn't pick up on that either, but I guess they aren't that stupid and noticed the new line alongside it.
More of the damage. I think I can safely assume these lines were never touched, judging by the green "CAUTION: FUEL" tape wrapped around it in several spots.
Now for the removal of the line: A self-tapping bolt in the front wheel well on the top of the frame, behind the spring and shock mount (at one point it was probably 10mm, it's now a 3/8)
A 13mm nut holding the inner frame bracket. This one is in the same proximity as the previous one. There's also an ABS deceleration sensor located in this spot, which should be unplugged or removed to make it easier to pull the fuel line bracket out of its place. Once again, I didn't use my penetrating oil because I'm an idiot and broke the stud, but thankfully it was halfway off so I still had some usable threads.
At this point it became apparent that the entire front fuel line assembly had to be removed as a unit. This includes disconnecting the pressure and return lines, and getting the fuel filter out of the way.
A simple disconnect of the lines from the engine side is normally all that is involved at this point, but in my case, those connections were seized, and the cheap plastic quick-connect tools were completely useless.
Onto plan B: Unbolting the fuel lines from the fuel rail and dragging them out along with the rest of the line.
Of course, the return line is buried under the upper intake plenum, so that had to come off too. I've had this off many times, so I begrudgingly did it again knowing I'd make short work out of it. Whatever.
(These two connections are 17 and 19mm)
Aaaaand, with some more finagling, there it is! One front fuel line assembly. The rear vapor line thankfully doesn't require as much effort to remove. Just a few annoying clips which can be carefully pried open and it'll slide right out from behind the cross members in the frame.
So....pictures.
Day 1
