corpflyboy
- October 24, 2013
- Melbourne, Florida
- 2014 Ford Explorer Sport
+1 on Jzales..use a hair dryer or a $20.00 Harborfreight.com heat gun and warm up that rear stock emblem then peel it off like an old sardine can. I used needle nose pliers and just rolled the tin metal around the pliers. Once removed, the plastic base will need a lil TLC to smooth out the old glue still remaining. Same thing-heat up the zig-zag glue shaped marks and they peel/break off with little effort.
Buzz
BTW You will need 3M double sided tape to mount it back on the rear of the vehicle. The old black gummy glue is tacky but will not secure it well the second time around. Remove it all with the help of heat and alcohol wash it for a nice surface to tape.
The double sided tape that is included with your tin emblem is strong enough to adhere to the plastic base. No need to add extra 3M tape to that area.
Hope this helps.
Buzz
Hope this helps.
