91nut
- June 1, 2002
- Sac, Ca
- '91 XLT
After taking a trip through Eagle lakes Ca. and the Fordyce trail in my stock 91 Explorer I was thinking about some major mods. Can't do them 'till I get money but that is what I get for being a teacher. I have a couple of good friends with well built Landcruisers and Cherokee's. I told them about buying a donor vehicle possibly a Bronco or a 75-82 F-150 or 250. Bronco's can be a little pricey and hard to find. It would be easy to find a F series pickup with a D44 and a 9 inch in the rear. I am looking for a full size swap with all the drivetrain from the tranny/ x fer case/ axles / springs/ and then a disc conversion in the rear.
I have searched the website for this type of transfer but with no luck. Has any done this before?
I think this would be the least expensive way to do it. I know I would be lengthening the drivelines and doing a little crossmember work along the frame to adapt the leaf spring if I decide to use the F series set-up. Any advice would be good because I need to make room in the budget.
After seeing the prices to get a driveshaft cut down to adapt a Bronco front axle and required equipment, I thought it would be worth a shot if someone has done this mod before.
P.S.- People were awed by the stock explorer's ability to clear a semi difficult trail in the Sierra Nevada's. Nothing but props.
Joe
Joe
