Updated info
Thank you for your response. Last night when I posted I was on my Ipod while my hubby was changing the transmission gasket. We found one vacuum leak and that was fixed last night. When we took her out for another test drive last night the transmission refused to go into first gear and we barely made it past the neighbors house. She does reverse fine and manually she is amazing but the transmission is not a manual transmission.One she heats up and the training fluid gets warm she has no problem shifting. Today we took her to get her scanned and the guy who did it was a lot more intelligent than the last guy. Here are the current codes:
P1747-ECC solenoid
P0743-TCC solenoid
P0750-Shift solenoid A
P0760-Shift solenoid B
P0765-Shift solenoid C
Didn't write it down-It whas Shift solenoid D though
Plus O2 sensor bank 1, sensor 2 and bank 2, sensor 2
That is the short and long of it, the guy who scanned her said if all the transmission solenoids are showing bad there is more than likley a wiring issue because this is the second set of solenoids we put in.
Also a little more info on the current explorer: She has been sitting for at least a year under a tree. We have gone over most of the wiring searching for things like chewng from mice ants etc. All the parts I used in the current truck are from my old identical truck (which is now gone). My old explorer had the recall plastic guides which shattered and she jumped timing upon turning her off. That was the previouse trucks only issue. I can agree both back O2 sensors are bad on the current truck but I know for a fact the solenoids I put into it are good because the previouse truck shifted like a dream. Also the gentleman who scanned the truck this time said the hesitation could be comming from from her trying to second gear start. When we manually shift her from 1st to second all her power is where it needs to be and there is 0 hesitation. While having the training pan off we checked for metal shavings plastic bits and everything else that could be seen inside the pan and all looks well. Any help, theories, transmission wiring diagrams would be very welcome at this point. I have access to meters scanners and possibly a lift. One more thing once we reach cruising speeds she shifts fine but her RPMs rev a little high. Her tempature is normal, oil pressure normal ,and battery charge is normal.
Thank you Nikki
