fuse for the door ajar light | Ford Explorer Forums - Serious Explorations
fordhogg143
Suffolk, VA
2002 Explorer
The door ajar light stays on and keeps the interior lights on for a couple of minutes. I read somewhere that someone said to change out the fuse for it and that might take care of the door ajar light on the dash. Any idea which one of the fuses it is and where is it located?
Once again, thanks to this forum for providing a simple answer to a simple problem, rather than the dealers $150 fishing expedition!
Lube the door latches....."door ajar" warning disappears......problem solved!
Thanks!
2002 Explorer 4x4 Ltd
Good place to start. yes?
Welcome aboard!! :salute:
I have moved your thread into the Stock 2002 - 2005 Explorers Sub Forum.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 3 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ. I had to repair the pink/black wire to fix the driver door lock actuator.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums//showthread.php?t=270081
Unfortunately the pictures are no longer available in the above thread. IIRC, I believe I unwrapped the wires enough to gain access. When I have gone searching in there I had an idea of what wire I was looking for. I located the the wire I was looking for and gently tugged on that wire on the door side. The wire was pulled toward me and out of the harness. I then went inside the vehicle and gently tugged on the the wire I was looking for and was able to pull it inside the vehicle. I then spliced a length of wire to the 2 ends, completing the circuit. I then gently pulled the excess into the door.
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Could also be related to the door ajar switch.
Here is a great thread for checking/replacing the door ajar switch, thanks to borland for the awesome write-up: http://www.explorerforum.com/forums/showthread.php?t=249253
That is a great write up.
On a side note, before going through a complete replacement of the switch, you can spray WD40 into the door latch opening on each door, as these become stuck sometimes....and this can alleviate the issue.
This worked for me, after going for more than a year of the "door ajar" light coming on occasionally...mainly after a car wash, high humidity, or rain....making me unable to lock/arm the vehicle from the door keypad and keeping the dome lights on. Worth a try....it worked for me :thumbsup:
Good luck getting it sorted. :thumbsup:
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
I am having this same problem... I tried the WD40 and no luck... it just turns my stomach to think that this is a COMMON problem and if I fix it this time I have more door sensors and switches just waiting to cause me grief =(
Check my post above. Start by checking the wires in the boot.
