Jay Myers
- April 10, 2018
- philadelphia pa
- 2005 XLT
Hi.
I recently purchased a 05 explorer xlt. The turn signals went out so i check fuses and all were good so i replaced the relay under the dash. Before i switched it i could manually make the turn signals work by blinking them myself with the turn signal lever, Afrer switching the relay i have no turn signal light at all. Then the radio went out, fuel gauge and power windows stopped working. When i switched the relay i forgot to unhook the battery but i didn't see any spark when i did it so i don't think i shorted anything but who knows. I have the manual and checked the fuses in the fuse panel for the radio, turn signals, windows and fuek gauge and none are burnt out. So now at this point I'm stuck. I'm assuming it a fuse under the hook in the fuse block but not sure. Anyone have any idea ? Any help would be appreciated ! Thank you !
