koda2000
- September 2, 2011
- x
I recently noticed my Check Engine Light did not come on when the ignition was turned on (failed bulb check). As I also had several burnt-out instrument illumination bulbs, I figured I'd also check and change the CEL bulb while I was in there.
Sure enough the CEL bulb was bad. My vehicle is 2wd, but apparently Ford puts bulbs in every location in the instrument cluster (probably just easier that way) so i had at least 3 extra bulbs in my cluster which did nothing. Ford also labels the circuit tape on the back of the cluster, which makes it easy to identify which bulb is for what. Rather than buying a new bulb, I just swapped the 4X4 LO bulb with the CEL. Not exactly a huge financial savings, but it saved me a trip back to the auto parts store. And yes, i replaced all the illumination bulbs, even the ones that still worked.
As for the cost of the #194 illum bulbs, AutoZone wanted $4.99 for two (it requires 6). I had a buddy of mine get me a bulk pack of 10 at O'Rielly's for 28 cents each (his cost). WalMart also sells #168LL bulbs for $1.98 for two where AZ wants $4.99 for the same Sylvania bulbs.
