Gas Gauge not working | Ford Explorer - Ford Ranger Forums - Serious Explorations
ajw1275
Location
Lakeland
Lakeland, FL
1999 Explorer XLT 5.0
I filled up the gas tank on my 1999 5.0 explorer and i get in this morning and the gas gauge says that the tank is empty. I go to fill up and the tank is still full and the gauge still reads empty. What could the problem be and how can i fix it?
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
ajw1275
Location
Lakeland
Lakeland, FL
It still runs fine tho. Think it wouldn't hut the truck to drive it for a week like that till I get paid again?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
koda2000
x
Either the sending unit in the tank is bad or the gauge on the dash is bad or the wire connecting the two is bad. Most likely it's the sending unit in the tank.
There's an electrical connector/plug on the inside of left frame rail behind the rear tire. It can be unplugged and (after consulting a wiring diagram) you can ground the sender wire on the gauge side. This should cause the fuel gauge to go to FULL. If it does, the problem is with the sender in the tank. It will need to be replaced. If you can do this yourself you're looking at anywhere from around $70-$700 for a replacement new fuel pump assembly (depending on brand and where you source it).
Link:
https://www.rockauto.com/en/catalog...fuel+&+air,fuel+pump+&+housing+assembly,10147
Having dealt with a similar problem on an old mini-van years ago, even trying to monitor/estimate fuel consumption you will run out of gas so carry a gas can with you until you get it fixed.
97-5.0
Hamilton, Ontario
1997 5.0 AWD
I had the same problem, but some times it would read half a tank past full!
The wire was broken off the little circuit board that's on the float on the sending unit, ground was also broken also
Soldered the wire back on the circuit board, connected the ground
Works mint, cost nothing
