  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
gas mileage/electrical?
AgInternational
Carpinteria, California
'91 Sport
I drove my 91 2 door sport about 30 minutes then shut it off. about an hour later, I started it up and the radio, blinkers(not the emergency flashers), power windows, and fan panel did not work. I drove for about 10 minutes then shut it off. about 2 hours later I started it and everything worked. that was 3 days ago and everything still works.
Now, since then my fuel gauge is dropping a lot faster, thus horrible gas mileage. I don't know if they are related or not. maybe its just a coincident. I'm not sure. Does anyone know why this is happening? anything helps, thanks.
Anime
EF YEAH!!
2018 EX Sport Concept
My guess would be the ECU. When the capacitors on the ECU motherboard get old, they leak, and can damage the other electrical components, or damage the pathways between them. The most common symptom is a vehicle that won't start even though everything else is fine, but other random electrical issues or strange problems with no explanation that come and go seemingly randomly have also been traced back to a bad ECU.
The solution is to remove the ECU and have the bad caps replaced with new ones, but since most people don't have the caps or soldering skills to do so, they either send it out for a refurbishing, or just buy a used ECU that hopefully lasts a little longer. You can't buy a new one anymore, and even if you could, they'd be hundreds of dollars. The caps themselves are only a few dollars apiece, if that, but the cost is in the equipment to do the job and the skill to do it without damage. You can buy semi-refurb'ed ones at auto parts store or on Rockauto for a hundred or so, and if they don't have yours in stock, they can take yours and refurb it instead. They don't always do a great job, but there aren't many other options unless you know someone who can do precision soldering.
AgInternational
'91 Sport
I also had one time where I turned the key, the dash lights all came on, but when I continued to turn everything went dead. I jumped it and all was well. no problems with that since.
Anime
EF YEAH!!
You might try just looking up under the dash with a flashlight, and also inspecting the engine compartment wiring as well. Even just replacing the underhood ECU relay with a good one might yield results. It could be a simpler, smaller electrical issue, but the ECU is my guess when it's wierd electrial issues.
Mettler
Monroe, WA
98 exploder sport 4x4
Do you have an alarm? check that too.
L Hard cold start bad gas mileage Stock 1991 - 1994 Explorers 20
M poor gas mileage/rough idle on start/lose power after warming up Stock 1991 - 1994 Explorers 21
M Poor Gas Mileage Stock 1991 - 1994 Explorers 24
S The First Gen's Quest for Better Gas Mileage Update 6/02/14 Stock 1991 - 1994 Explorers 12
S 1st Gen explorers gas mileage and how to increase! Stock 1991 - 1994 Explorers 32
B Best gas mileage possible Stock 1991 - 1994 Explorers 33
C Gas Mileage - 1994 4x4 XLT V6? Stock 1991 - 1994 Explorers 19
T Gas mileage troubles Stock 1991 - 1994 Explorers 3
M Best tips for better gas mileage Stock 1991 - 1994 Explorers 21
9 gas mileage seems off. Stock 1991 - 1994 Explorers 0
T Rough Idle, loss of power, horrible gas mileage Stock 1991 - 1994 Explorers 19
E Gas Mileage conundrum want the 21.5 back!!! Stock 1991 - 1994 Explorers 10
R Running Richo or low gas mileage? Try checking fuel pressure Stock 1991 - 1994 Explorers 1
F Explorer problem. It floods, and has bad gas mileage. Stock 1991 - 1994 Explorers 4
B Gas mileage. Stock 1991 - 1994 Explorers 104
J Engine light, poor gas mileage Stock 1991 - 1994 Explorers 10
P Gas: 89 Gives ~14MPG, 87 Gives ? (I need better mileage) Stock 1991 - 1994 Explorers 6
S Really Bad Gas Mileage Stock 1991 - 1994 Explorers 21
P 3.27 overdrive and gas mileage Stock 1991 - 1994 Explorers 23
P 94 explorer, poor gas mileage. . . . Stock 1991 - 1994 Explorers 60
SwaintaN 93 Explorer Gas mileage! <cool Stock 1991 - 1994 Explorers 25
P Gas Mileage with 3.23 ??? Stock 1991 - 1994 Explorers 4
P I just replaced the original PCV valve, could this have caused bad gas mileage? Stock 1991 - 1994 Explorers 6
James909 Gas mileage with 3.73's Stock 1991 - 1994 Explorers 13
JMan689 Trying to improve gas mileage Stock 1991 - 1994 Explorers 40
R Best shifting for maximum gas mileage? Stock 1991 - 1994 Explorers 9
M Hesitation, rough idle, lower gas mileage problem solved Stock 1991 - 1994 Explorers 0
M gas mileage Stock 1991 - 1994 Explorers 22
L Gas mileage...frustrating me. Stock 1991 - 1994 Explorers 32
P Brutal Gas Mileage Stock 1991 - 1994 Explorers 12
N bad gas mileage problem Stock 1991 - 1994 Explorers 12
H ways to improve gas mileage Stock 1991 - 1994 Explorers 2
W Gas Mileage Stock 1991 - 1994 Explorers 29
S Stuck gas pedal - Scary! Stock 1991 - 1994 Explorers 6
A Water in the gas? Stock 1991 - 1994 Explorers 5
7 Gas Tank Stock 1991 - 1994 Explorers 7
D dropping the gas tank Stock 1991 - 1994 Explorers 14
T getting ready for cross country trek: need advice on improving gas mpg Plus Stock 1991 - 1994 Explorers 10
T 93 stalls when giving gas pulling away from stop sign Stock 1991 - 1994 Explorers 2
D Premium Gas, or Standard? Stock 1991 - 1994 Explorers 10
B Where can I go to fix the gas and coolant gauges for a 93 Explorer? Stock 1991 - 1994 Explorers 6
A 1993 Explorer Gas leak Cant Find it Stock 1991 - 1994 Explorers 5
G non-working gas and temperature gauges Stock 1991 - 1994 Explorers 4
D Gas gauge only works when vehicle is off Stock 1991 - 1994 Explorers 0
T gas cap missing Stock 1991 - 1994 Explorers 9
B Gas Gauge issues Stock 1991 - 1994 Explorers 9
N Newbie has broken gas pedal..Help! Stock 1991 - 1994 Explorers 6
mgmgmg Gas skid plate Stock 1991 - 1994 Explorers 5
9 need help with gas gauge problem Stock 1991 - 1994 Explorers 2
T No gas pedal! Stock 1991 - 1994 Explorers 13
Similar threads
