Gauge cluster lights | Ford Explorer - Ford Ranger Forums - Serious Explorations
I know that 194 bulbs will fit in the cluster, but does anyone know if the 906 type bulbs will fit. I know they will fit in the socket, but will there be enough clearance between the socket and the gauges for the bigger bulb to fit? If anyone knows or has access to a cluster that can test this for me, I would really appeciate it. I am wanting to replace the clear bulbs with blue bulbs and I would like the blue to really stand out.
Thanks!
Saleen_SR71
San Jose, CA
'97 EB 5.0
i have an extra cluster.
assuming the 906 is a 912 replacement...
no, the head is to big
mdriggan
Little Rock, AR
'97 Explorer Expedition
Ok I got bored today and tested the clearance of the 906 bulbs. The results....no big suprise.....they do not fit. The 906 bulb is too tall to fit into the cluster. So, I will continue using 194s.
Michael
Saleen_SR71
San Jose, CA
'97 EB 5.0
Michael
they werent to wide? just to tall?
mdriggan
Little Rock, AR
Yeah, the glass "post" on the underside of the gauge pod hits the top of the bulb and will not "seat" into the cluster. The width would be fine, just the height is the problem. Im considering using the 194 hyper white bulbs with blue gel caps. Im also wondering if the bulbs will get to hot and melt the caps? Dont need a fire in my face driving down the highway..... :eek:
Michael
Afboy143
Tampa,FL
1999 Ford Explorer Sport
Michael
id prolly use LED bulbs since they draw less power than regular bulbs and are brighter.
a big question of mine would be
How many bulbs do I need
Should I get the 5 watt LED bulb or 25 watt bulb?
mdriggan
Little Rock, AR
You would need 6 bulbs total. Im not sure of the wattage. I would like to try LEDS but I have not had good luck with the ones I have experimented with and have had to return them. My only concern with LEDS in the cluster is that there will be a bright spot where the light is then start to fade as the light speads out over the dial. I am trying to get a uniform look, so thats why im staying with the regular type bulbs. Only blue in this case.Hope this helps.
Michael
