Gear Install (front and rear)
SSR
Chicago Ridge, IL
94 XLT
Ok I have a 94 explorer that has (i think) 3.27 gears, and i want to put in 3.73s, my question is what kind of gear does the front axle use? I was told the rear is an 8.8, but not sure about front. Please help
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
The front should be a Dana 35.
SSR
Chicago Ridge, IL
94 XLT
So the rear is an 8.8 right? Also, where can i buy 3.73s for the front?
sirhk100
las vegas
'91
If you're interested I'm getting 4:56s installed today (10/8). they pulled both the front and rear apart this morning and let me know that a axle shaft is worn out in the rear so it won't be ready till tomorrow. Anyways, I had 3.73s from the factory and would be willing to sell them if you're interested. The gears have 105,000 on but should be in good shape. They've always had sythetic gear oil in them and I'm swapping them out just for the lower gearing not because they are bad. I'll inspect them when I get them back and as long there is nothing wrong and they don't look worn or anything I plan on selling them just to get a little cash back. My new gears are costing me $1500 installed cause I had a axle and some bearings that had worn so that ended up being another $225 on top of just the gears and install.
madmike need help w/new gear install!!!!!!! Modified Explorations 5
Creager Whirring noises: recent re-gear related? Modified Explorations 12
S 31s on stock running gear Modified Explorations 4
J Re-Gear Lately? Modified Explorations 12
celly White faced cluster, 4WD, with gear indicator Modified Explorations 13
S Redline Synthetic Gear Oil for the Diff Modified Explorations 14
R Gen 3 Speedo Gear help Modified Explorations 4
beast 4.10 gear ratio??? Modified Explorations 11
gfennie77 5.0 w/ C4 - Stalls in gear Modified Explorations 6
D Gear question Modified Explorations 5
S front and rear gear change???? Modified Explorations 2
A More Gear and Locker ?'s Modified Explorations 6
S gear changing question. Modified Explorations 1
R Speed O Gear Modified Explorations 6
9 TT gear puller size? Modified Explorations 9
B gear ratio Modified Explorations 6
B Locker and gear setups q's Modified Explorations 1
H Hi, should I go 3.73 or 4.10 from my stock 3.27 gear? Modified Explorations 5
B gear swap Modified Explorations 5
B Do i need to re-gear? Modified Explorations 6
B Spacers/gear ratio Modified Explorations 3
M Gear Swapping Modified Explorations 4
A gear change cost??? Modified Explorations 8
B Gear Logic...someone check me up on this and make sure I'm right Modified Explorations 3
Skunk Gear Rotation 98sport Modified Explorations 3
H Speedo Gear / Tooth Modified Explorations 5
C Gear question. Modified Explorations 2
A 1999 Explorer gear ratios Modified Explorations 2
P gear swap on AWD- anyone???? Modified Explorations 11
ld50 I got the diff gear confusion blues! Modified Explorations 5
Z Gear reducing drive shaft or hubs? Modified Explorations 11
Derrick C. Help with speedo gear..... Modified Explorations 3
W Speedo gear for 97? Modified Explorations 14
G Tranny Mod or Gear mod Modified Explorations 2
J gear swap questions Modified Explorations 5
R speedo gear color for 35's and 4.56s Modified Explorations 5
S UPDATED ARB locker discharging gear oil Modified Explorations 8
L To gear or not to gear.... Modified Explorations 11
Alec Argh! Diff and gear q's Modified Explorations 12
JamminG4Jim What gear ratio should I look for. Modified Explorations 6
F Gear swap - any last comments? Modified Explorations 8
CBoug76 Tire/Gear Calculator Modified Explorations 1
N Teeth on Rng Gear Modified Explorations 1
C Front Gear Replacement Cost? Modified Explorations 2
B Gear Ratio and RPM's Modified Explorations 4
S gear cal Modified Explorations 5
M Low Gear Ratios for V8 AWD? Modified Explorations 1
R More Gear? Modified Explorations 0
I Gear ratio's Modified Explorations 5
T gear ratios Modified Explorations 1
Similar threads
