N2FORD
- January 20, 2002
- Kingston,TN
- 2001 Sport Trac 4wd
Sorry in advance for the long story. I have a 01 Sport Trac with a 8.8 4.10 trac loc. The pinion bearing had gone bad, lots of noise and movement. I decided to try and find a good used one. Found one at the pull a part near me and it seemed really good and tight with no leaks. I put it in about six months ago and added a heavy duty rear end cover. I added the proper fluid and filled to the fill plug on the rear cover. That plug is a little higher than the front plug. The rear end started to blow fluid out of the vent tube if driven on the interstate. I thought at first it was just a little over full and would settle. It did seem to get better. A couple of weeks ago it got warm enough to roll the back window down. Wow what I heard scared me, the rear end is howling pretty bad. Changes as I roll on and off the gas. Checked the fluid and it was still full by the front plug. Took the cover off and the gears seemed shiny and the fluid seemed frothy. So I have now gone to pull a part and picked up another rear end. My question is did the overfilling of the rear end cause my problem or the extra capacity with the larger cover cause the frothy fluid to cause the overflow issue? Just wanted advice before I decide if I want to use that cover again or not.
