Gear shift problem lots of play no park
Business socks
Monroe nc
2001 mountaineer monterey
I have 2001 mountaineer that drives like a dream. The other day I get in to find the shifter on the column has alot of play. I'm having trouble getting into park and 1. After a week of this it gets progressively worse. I can't get into park or 1 at all. I can put it into where park is and get my keys out but its not in park. I called 20 dealership just to get I've never heard that before answers. I am pretty mechanically inclined so if anyone has ideas please help me out. Thanks. Oh I searched the forumns for this and found where shifters broke off and the indicator was off but nothing was just like this. I just have mass quantity of play and can't get it into park
team
i would get underneath the vehicle and make sure the shifter cable is still securely in the bracket attached to the transmission. You may need to readjust it if the lock on it is loose.
cjryan 4R55E Transmission - Shift Solenoid/Gear 2 Problem Stock 1995 - 2001 Explorers 15
I Gear shift indicator Stock 1995 - 2001 Explorers 6
T 5r55e 4th gear to 5th gear shift issue Stock 1995 - 2001 Explorers 4
1 98 Explorer 5 Speed Won't Shift Into Gear Stock 1995 - 2001 Explorers 3
H won't shift into park lock into any gear or start Stock 1995 - 2001 Explorers 1
M Won't shift into gear Stock 1995 - 2001 Explorers 0
P 97 AWD, Bang/Clunk under acceleration or gear shift from front end. HELP! Stock 1995 - 2001 Explorers 22
J Gear shift seems to be loose on my 1996 Ford Explorer Stock 1995 - 2001 Explorers 4
K Gear Shift Knob: 98 Explorer Sport 5-Speed Stock 1995 - 2001 Explorers 5
Swinson1974 Shift Indicator off by a gear. Stock 1995 - 2001 Explorers 5
S Gear shift problems Stock 1995 - 2001 Explorers 3
A 99 Explorer Shift Delay going into gear not while driving Stock 1995 - 2001 Explorers 2
B 1996 Explorer XL. Gear shift indicator issue. Stock 1995 - 2001 Explorers 2
E Gear shift lag, poor MPG Stock 1995 - 2001 Explorers 1
K My 1996 Explorer won't shift into gear. Stock 1995 - 2001 Explorers 2
A Gear shift is stuck in park when cold. Stock 1995 - 2001 Explorers 3
D Check Gage + Hard shift + Gear slippage at same time? Stock 1995 - 2001 Explorers 3
C Gear shift lever / selector binding Stock 1995 - 2001 Explorers 6
W Gear shift has slid down a notch Stock 1995 - 2001 Explorers 4
F Will not shift out of 1 st gear? Stock 1995 - 2001 Explorers 0
K My vehicle stalls when I shift into gear. Stock 1995 - 2001 Explorers 4
N '95 Explorer Gear Shift Piece - What is this? (Pix) Stock 1995 - 2001 Explorers 1
S broken gear shift linkage..i fixed it..! Stock 1995 - 2001 Explorers 3
H gear shift lever and o/d Stock 1995 - 2001 Explorers 6
T A/T shift indicator showing incorrect gear? Stock 1995 - 2001 Explorers 6
R gear shift lever stuck Stock 1995 - 2001 Explorers 0
B Shift / Gear Indicator Stock 1995 - 2001 Explorers 1
M Gear shift worn Stock 1995 - 2001 Explorers 0
C gear shift indicator Stock 1995 - 2001 Explorers 0
7 gear / shift indicator broken Stock 1995 - 2001 Explorers 1
M 5R55E pump gear set 16T versus 24T Stock 1995 - 2001 Explorers 0
W 2000 Mountaineer 4.0 SOHC P0174 backfires when in gear accelerating Stock 1995 - 2001 Explorers 24
M Clicking noise in 3rd gear (Manual transmission) Stock 1995 - 2001 Explorers 6
K 1999 Ford Explorer shifts out of gear going uphill... Stock 1995 - 2001 Explorers 16
C Gear oil for Explorer 8.8 with limited slip? Stock 1995 - 2001 Explorers 38
ProjectAviator 99 Ex manual trans not going into gear. Stock 1995 - 2001 Explorers 10
D Gear Indicator problem Stock 1995 - 2001 Explorers 7
S Gear selector not working on 1997 Manual Ford Explorer XL 4WD RHD Stock 1995 - 2001 Explorers 4
R 1999 AWD 5.0 gear oil in my transfer case. What do I do? Stock 1995 - 2001 Explorers 1
S Rear parking brake and gear noise Stock 1995 - 2001 Explorers 2
B Gear Selector Needle Out of Whack Stock 1995 - 2001 Explorers 6
J '99 5.0L V8 - Engaged gear doesn't match shifter position. Stock 1995 - 2001 Explorers 13
D 2000 explorer stalls when put in gear Stock 1995 - 2001 Explorers 11
W Stuttering in gear. Stock 1995 - 2001 Explorers 10
sattech2000 Would Gear change help improve MPG? (USPS Mail delivery vehicle with a ton of start/stops.) Stock 1995 - 2001 Explorers 12
H Transmission slipping out of gear Stock 1995 - 2001 Explorers 0
A Steering column 95 Explorer gear shifter Stock 1995 - 2001 Explorers 1
M No first manual first gear for rebuilt 5R55E Stock 1995 - 2001 Explorers 0
C Finally did a full gear oil change in rear axle differential on my Explorer Stock 1995 - 2001 Explorers 2
J 1995 Ford Explorer stuck in first gear. Stock 1995 - 2001 Explorers 1
Similar threads
