spguest
- July 15, 2009
- Bellevue, WA
- '95 Limited
Hi – I have a ’95 Limited with EATC. Recently it smelt as if something was burning outside but not inside and I could not find the cause. Then the blower motor stopped but it will rotate slowly if tapped. As it will spin slowly I am assuming the fuses and relays are working. Thus I think it is the blower control module - part # F1SH 19E624 AC. After searching the forum my attempt to fix this has left me puzzled and I have a few related questions.
- I can’t move the reservoir bottle unit far enough away to get good access to the fan and control unit. The air intake duct is in the way. The manual says pop it off its pins and pull it away from the fender. It pops off the bottom just fine but is attached by a fixing above which will not release. I tried prying it out, first the center pin and then the whole unit – but it won’t budge. What is the trick to remove this round type of air intake duct?
- As I searched for the solution to this I found what looks like a switch hanging loosely between the reservoir bottle unit and the air intake duct. Looking at the design it seems it once bolted to the fender. In this location it should have been pressed when the hood closed. I tried pressing it to see if something like the hood light went out but nothing seemed to happen. It is not in my manual. What is it supposed to do and why should it be left hanging loose?
