gjanick
- February 28, 2010
- St. Thomas, ND
- '94 Limited
I have a 1994 Explorer Limited. I just replaced a broken (fender-mounted) starter solenoid switch and installed a new battery. I cleaned up all the contact points in the switch and battery wires and cables, and tightened all connections securely. However, I have no power whatsoever or electrical to anything (including headlights, interior lights, ignition, etc, etc.). What in the world could the problem be? Everything was working fine prior to the work described above! I am new to the forum-- I sure could use the expertise! Thanks, Greg.
