Good for the money? | Ford Explorer Forums - Serious Explorations
Good for the money?
Status
Not open for further replies.
Noober1
Tulsa, Oklahoma
92 Mazda Navajo
I'm going with 33" tires, unless 35" tires and lift drop out of the sky. For the money, is this a good deal?
Ford Ranger Suspension Lift Kit Ford Ranger Suspension Lift +Click to Enlarge
Price: $440.95
http://www.roughcountry.com/suspension/4wd-ford/ranger_83-97_4.html
Kit Contents:
Front: Lifted coil springs, radius arm drop brackets, I-beam drop brackets, bump-stop drop brackets, power steering pitman arm, and hardware.
Rear: Lifted blocks and u-bolts.
Option: Available w/new rear leaf springs. +$240
Shocks: Kit includes (4) Hydro 8000 series shocks.
Any opinions?
i havent used it myself but ive read a ton of opinions on this set up on the forum. just do a search on rough country lifts.
I'm no expert but here is what I know.
1. The pivot drop plate for the passenger side beam has a history of punching holes in the top of the front pumpkin :thumbdwn::thumbdwn::thumbdwn:
2. The rear lift parts are for a spring over application, the Explorer is spring under so those items are useless. If you do convert the X axle to spring over, that alone will give you approx 5.5" of lift. You;ll need to check the leaf spring option to make sure they are right for the Explorer application.
I recommend the good stuff from the beginning. Skyjacker or better yet James Duff
Thanks for the time you spent answering. I've looked for a skyjacker but there isn't one listed for an Explorer. (except maybe a spring) James Duff.... looks like good stuff...pricey though.
Status
