mattadams
Moderator Emeritus
- September 17, 1999
- Longmont, CO
- 2017 Explorer Sport
good ol stupidlift... (well, at least they are replacing the parts for free...)
Recently broke an axle drop-down bracket, passenger side. Welded it up, but need it replaced. Did a pretty good inspection, noticed one radius arm had a crack in it, probably about 1/2" long. The other side had a 1/4" long crack. So they're sending out the newer replacements which are supposedly more reinforced.
Also, the springs were sagging, so they are replacing those with the newer versions.
Planning on doing all of the work next weekend, so I get under there today to do a more thourough investigation, find that one of my radius arm brackets is cracked right along the line, the other one is bent and forming a crack along that line as well. So those are going to need to be replaced. So in other words, the only parts of the front suspension that DONT need to be replaced are going to be the stop blocks which limit the articulation, and the passenger side axle drop down bracket (which, believe me, I looked over REAL good).
So, about two years after having installed the superlift lift, everything except for the rear Spring Over Axle brackets, front axle stop blocks, and front drivers side axle drop down bracket need to be replaced.
I didn't think I wheeled it THAT hard, LOL.
