SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I'm in the middle of a timing chain replacement project that obviously requires the timing chain cover to be removed. To get it off you have to remove 16 bolts bolts from the face of the cover plus 4 bolts from the oil pan that thread through the pan and into the bottom of the cover. This exposes the front 2 inches of the oil pan and obviously the front part of the oil pan gasket is what you are looking at when the cover is removed. There's no way to replace the oil pan gasket unless the pan is removed.
I'm concerned that when I torque the front part of the oil pan back onto the bottom of the timing chain cover that it might leak because I'm reusing the 14 year old original factory gasket. I'm guessing it's a bad idea or pointless since the bottom portion that touches the pan side would not or could not receive the extra RTV so why bother with the top.
Theoretically, the gasket should be clean and dry before installation but I don't have the option of a new clean gasket. So what would you do to clean the surface of the exposed part of the oil pan gasket before mating the timing chain cover? There's got to be something I can do to minimize chances of oil seeping out.
