jdxprs
- April 4, 2007
- 08 explorer eddie bauer
today, my truck was running terrible and had no power. i left it run in the driveway for about 20 minutes, and finally a check engine code came in.
The code was P0353. Ignition coil C Primary/secondary circuit malfunction.
i pulled the wires off the ignition coil one at a time, and on the two in the middle, which are wires 2 and 6, i had no spark and there was no change to the way the engine was running like there was when i pulled the wires off the other 4.
I went and picked up a coil pack and installed it. When i started the truck it ran perfect for about 5 minutes, then the problem came back. same thing. running really rough and no power.
about 2 minutes later the problem stopped and the truck ran perfect again.
This is happening on and off now. it keeps coming and going. the computer spit out the same code again 1 time when it was running rough, but the truck started running good again and i was able to clear the code and it hasnt come back yet.
The only things I can add to this, is that the truck was very low on gas. down to 15 miles to empty when this started. i have since added fuel injector cleaner and filled up with gas.
The other thing, is if i get on the highway with it, and gun it, i can hear a couple of popping sounds from the engine like a quiet backfire.
the truck has 83,000 miles on it.
CAN ANYONE HELP??? I've searched the forum and seen others with similar problems but i cant find any SOLUTIONS or CAUSES.
