got some more trouble codes!
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
well its that time again ... fixed an antifreeze leak and connected my code reader and got these:
U1900 controller area network communication bus malfunction receive malfunction NON-MIL
B1805 mismatched PCM and / or ABS-TC module NON-MIL
C2900 vehicle identification number mismatch NON-MIL
ive searched on other OBD II websites but haven't found anything anybody had these codes before?
waskly
Crooklyn NY!
do you have an abs light on or check traction control?
if not clear them.
if they dont stay cleared, get abs module PMI with an ids.
if it can't be PMI ( does not accept programming)you need a new abs ecu.
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
no lights were on ... not even the CEL i just randomly plug in the scanner and found them but yes i cleared them
and triton did your truck run a little rough when you had the codes? mine seems to have a little hesitation and a little (very little) skip at idle
Triton8273
I can't quite remember, I had a lot going on with the truck in one month. Had the fuel rail pressure sensor code, cyl 1 misfire, C02 code (due to catback), and then the codes you listed.
Whenever I get a code that relates to something that isn't easy to check on my own real quick, I just reset it and then if it comes back I will worry. Not much you can do in your case because when I searched those codes I found a lot of possible problems and none of them were anything that I knew anything about.
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
i erased the codes and will see if they some back ... wiht codes like that i guess thats the only way lol
