Gps not working | Ford Explorer - Ford Ranger Forums - Serious Explorations
Gps not working
Denmo
Oroville, ca.
2007 explorer sport trac
Have 2007 explorer with non working gps. Installed dvd update but no work. It shows my location in Mi. I am in California. Could it be a bad gps antenna?
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Fix4Dirt
Get a Load O' This Guy!
Los Angeles, CA
1998 XLT 4x4
i would doubt its an antenna. usually it has to triangulate within a bunch of satilites, so unlikely its that. have you tried resettng (ie disconnecting battery for >10 mins)
Denmo
Oroville, ca.
Yes disconnected several times. Battery went dead so disconnected it and charged it. Now clock and calendar Don’t work. Diagnostic test says no satellites are detected. The dvd map works but gps doesn’t show exactly where you are. Says you are in Michigan insread of California. Tryed removing gps antenna but couldn’t find it under dashboard. Pioneer navigation unit
Fix4Dirt
Los Angeles, CA
1998 XLT 4x4
not entirely sure let me think
JeffreyM
Florida
2008 Explorer Limited 4.6
If it is not receiving a gps signal, there will be a 'GPS' symbol w/ red circle w/ line through it in the upper left corner, right next to the NORTH indicator. The GPS antenna has a pink connector in the back of the radio, just above the black am/fm antenna connector. I'm not sure exactly where the actual gps antenna is located. I beleive MI is the default location until it acquires a gps fix.
Fix4Dirt
Los Angeles, CA
1998 XLT 4x4
really, mi? thats interesting! is it cause ford is based there?
JeffreyM
Florida
That must be the reason. I have acquired a couple nav units, and they all default to MI without an antenna. I have been trying (unsuccessfully) to add nav and sync to my 2006 Limited. I've read several posts where others have done this, using a sync install kit for a Mustang. I wish I could reach out to those people, but all of the posts are over 5 years old, so they have likely moved on to a newer car.
94Eddie
2010 Mountaineer Premier
I believe the GPS antenna is located behind the rear view mirror. It has two short antennas that are about 2" long.
