aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
My interest in the Granatelli MAF (http://www.granatellimotorsports.com ) was in its potential ability to improve gas mileage, performance boost is a nice bonus for me.
The Granatelli MAF is physically different from the stock MAF; take a look at the end view photograph of the to units ( the stock MAF is on the left ).
The installation of the Granatelli MAF is a simple one. First the battery negative terminal is removed, and then I removed the bracket holding the KKM filter and loosened the hose clamp holding the stock MAF to the intake tube.
Next, on the workbench, the stock MAF was unbolted from the KKM and the Granatelli MAF bolted to the KKM. Now, back at the truck, the Granatelli MAF was reattached to the intake tube and the hose clamp tightened. The electrical connector was now attached to the new MAF. The battery cable was then reconnected. A final look to see that everything was installed properly was done.
The complete install took about 15 minutes.
Time has come to crank the truck; she fired immediately. The idle was normal for a cold start.
A quick road test of about 20 miles was performed. There was a noticeable boost in acceleration from 2000 RPM. There was a bit more “throaty” noise from the intake, whicj I anticipated due to the ~40% larger MAF. It also appears that less throttle pressure is needed to maintain a given speed. I anticipate a long trip soon to determine the effect of gas mileage.
