ukobach
- February 2, 2010
- Alabama
- 97 Explorer 5pd Auto 4x4
OK, Im no mechanic but my opinion if a trans is going bad your going to have problems getting in the gear, getting it to pull in any gear, or grinding tryn to get it into a gear.
This is a 97 2d 5 speed Auto 4x4. Ford Explorer
When I put it in first and start there is no issue its perfect.
Shifting gears perfect.
When I let off the gas and it slows down without takeing it out of gear or mashing the clutch it starts makeing a grinding noise as if someone tryn to put one in gear without useing a clutch.
I mash the gas it makes a clunk in the rear and then just goes as if theres nothing wrong till I let of the gas again.
I can shift down but when I do it makes a grinding noise as if im not useing the clutch again and when I accelerate it stops.
People down here are so insistant on selling me a 1200 doller transmission that I cant afford at this time instead of actually looking at the problem.
Any information would be helpfull as before the clutch works fine and there are no issues untill i decellerate or accelerate after while still moveing.
