nismotunedgtr
- September 11, 2004
- Windham, Maine
- '93 XLT 250k miles
1993 Explorer XLT 4x4 249k miles.
Problems:
-When driving 0mph - 75+ the steering wheel shakes, the front end vibrates, the whole truck does....
-There is atleast 2" of play turning the wheel back and forth.
-Turning right there is a grinding/growling, vibration, right wheel grabs sometimes. When this happens the wheel doesn't return like it should. But this doesn't always happen.
-Power steering fluid (ATF) leaks all over the pitman shaft 1/4 quart every oil change.
What's been done recently:
-Radius arm brackets and busings (239k)
-Brakes all around (240k)
-Shocks all around (240k)
-Full tuneup (245k)
-Passenger side wheel bearing (week ago)
-Rear spring shackles (239k)
It doesn't get worse with braking. The noise / rumble / vibration gets faster with speed. Ball joing and steering components all seem to be tight (havn't had the wheels off the ground to really test. But pushed the truck side to side HARD and ball joints didn't move.
It growls / grinds pretty good when the wheels are turned lock to lock parked. When wheels are turned lock to lock parked the axle shafts turn?
Really stumped here!
Problems:
-Full tuneup (245k)
