Jodogg, In 1997, the 4.0 L engine came with control-Trac which had three driver settings. When mine was set to Auto, 96% of the torque should have been sent to the rear axle. In my case, too much power was sent to the front axle, which did not allow the front tires to slip on dry pavement. The 5.0 L engine came with AWD, where normally 65% of the power goes to the rear. It is not clear whether the TSB refers to the AWD system, but the dealer could tell you.
Article No. TSB
97-21-15
10/13/97
^ SHUDDER OR BINDING SENSATION - IN TIGHT
TURNS WHILE VEHICLE IS IN 4X4 AUTO MODE -
VEHICLES BUILT THROUGH APRIL 1997
^ TRANSFER CASE - SHUDDER/BINDING SENSATION
IN TIGHT TURNS WHILE VEHICLE IS IN 4X4 AUTO
MODE - VEHICLES BUILT THROUGH APRIL 1997
LIGHT TRUCK:
1995-97 EXPLORER
ISSUE:
A shudder or binding sensation in tight turns while in 4X4 Auto Mode may be experienced on some vehicles. The shudder is due to a high torque output from the clutch in some transfer cases.
ACTION:
Recalibrate the existing Generic Electronic Module (GEM) if the GEM is identified with engineering part number F77B-14B205-BB. The revised calibration commands a lower torque which allows the transfer case clutch to engage smoother so shudder or binding should not result. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Using Service Bay Diagnostic System (SBDS) machine, use the latest software release to recalibrate the GEM to command a lower minimum torque level from the transfer case. Follow the instructions below:
1. Select "Body, Chassis, Electrical" from the SBDS Main Menu.
2. Enter the Vehicle Identification Number (VIN) of the vehicle being serviced and continue to the "Body, Chassis, Electrical" menu.
3. Select "Module Reprogramming" under the "Category" scroll box, and "Module Reprogramming" under the "Tool" scroll box.
4. Follow all on-screen instructions, continue to "Module Reprogramming Procedure" screen and select "GEM Module, Shudder in 4X4 Auto Fix, 4X4 Auto Fix."
5. Again, continue and follow all on-screen instructions until the GEM module has been reprogrammed.
6. A copy of the log can now be printed to document what has been done to the vehicle.
If the new calibration does not satisfactorily resolve the concern, refer to TSB 97-3-14 for additional corrective actions.
