Halos And Relay Harnesses For An XSport
gadgetball
Location
Kennesaw Georgia
Kennesaw GA
2013 Ford Explorer Sport
Anyone doing halo kits in a 2013 Ford XSport? What size halos will fit on the projector lens of the halogen headlight and foglight housings?
I ordered some from Summit Racing that said they were vehicle specific but they were not the correct size (too small).
Also any suggestions on a reliable relay harness to run these as DRL? There are numerous harnesses available but some reviewers say certain ones are crap...
T LED Halos for fog lights Performance Lighting 17
F New Halos on my 05 Explorer Performance Lighting 0
F Custom Halos on an 05 Performance Lighting 0
4 Flashtech Halos in HD! Explorer and Charger! Performance Lighting 7
B Projector Lens Kit w/ halos installation problem. Performance Lighting 23
C halos Performance Lighting 2
D Auxiliary backup lights relay question Performance Lighting 4
9 Help With Relay For Lights Performance Lighting 4
Greg_DonWindsor 2nd Gen, remove DRL relay with HID's??? Performance Lighting 3
J Fog lamp relay question! Performance Lighting 4
V Would i need a Cancler and/or relay harness for a 1995 ford explorer HID kit? Performance Lighting 1
P headlight relay mod problems Performance Lighting 1
dustinjorge Adventures in relay box perfection... Performance Lighting 4
T Stock Fog Light Relay Performance Lighting 3
C HID Relay Harness help Performance Lighting 3
J relay questions???? Performance Lighting 14
J HID Flicker ( I used a relay harness) Performance Lighting 21
M Fog Lamp Relay box... Performance Lighting 2
J Bosch Relay Gurus Performance Lighting 6
J HID relay wire harness question Performance Lighting 6
S Flashers Exposed, well at least where the relay is... Performance Lighting 0
P Relay for LEDs using Rocker Switch? Performance Lighting 3
D Pickup a stock fog light relay Performance Lighting 2
D Factory fog light switch and Bosch relay Performance Lighting 4
P Some Complex Relay Harness Schematics (my contribution) Performance Lighting 18
P simple relay? where to buy? Performance Lighting 17
S relay question Performance Lighting 7
C How hot will relay get? Performance Lighting 6
little x 5 pin relay wire guide Performance Lighting 4
O Where to tap 12v for lamp relay switches? Performance Lighting 10
Flounder PIAA 510 Relay Performance Lighting 24
P Oem Fog Lamp Relay Location??? Performance Lighting 0
MadScotsMan Relay Question Performance Lighting 2
M Wiring Harness/Relay Upgrades for '98 Explorer? Performance Lighting 11
D Headlight Relay Location Performance Lighting 3
E 91, where is headlight relay? Performance Lighting 1
B Hella's blew relay, replaced now lights aren't as bright Performance Lighting 4
M relay wiring questions Performance Lighting 3
P PIAA's out. Fuse good! Could be relay? Performance Lighting 25
D fuse and relay question Performance Lighting 2
D Fog light relay questions Performance Lighting 9
P help me wire driving lights with relay- Performance Lighting 7
Crankcase 5 Pin Relay Question Performance Lighting 4
LiKuiD PLEASE Help me with this f#$@%$ relay!!!!!!!! Performance Lighting 16
M Questions on hooking some aux lighting up (neons) and which relay to buy. Performance Lighting 0
I Wiring Stock switch to PIAA relay Performance Lighting 4
Dannyboy Help, wired lights with relay, shorted EVERYTHING! Performance Lighting 7
B Simple (maybe) PIAA relay question Performance Lighting 10
J headlamp relay Performance Lighting 2
Z Relay Access Performance Lighting 2
Similar threads
