LOCKONS7RA7US
- August 14, 2015
- Location
- Everett , wa
- Everett washington
- 1992 , eddie bauer
- Callsign
- Taco Run
Hello everyone so lately I have been having trouble with my 92 x eddie bauer edition. When I start it up cold it it kicks over fine and runs and idles but after 2-3 mins then it starts to lower the idle then starts to bog until it cuts out and kills the motor. I'll restart it and will be fine but then restart the lower idle and boging . I step on the gas while it's boging and after 1-2 mins holding the gas pedal at 2k rpm it will be fine sometimes I have to do it longer. When it's warmed up then runs fine like nothings run with it but if I leave it sit for more then 3 hrs then I have to go through all the bullshit again. I have also noticed to that I get bad gas mileage I barely make 200 miles a tank .
I've done the all sorts of research and replaced alot to no success
So far
Mass air flow sensor
Air filter
Mass air flow unit / metal housing
Top radiator hose
Bottom radiator hose
Thermostat
Coolant temp sensor
Coolant temp sender
Throttle position sensor
Idle air control valve
Pcv valve
Air intake temp sensor
Eec relay
Fuel pump relay
Wot relay
Pcm
Fuel filter
Spark plugs
Spark plug wires
O2 sensor
Soo that being said I may be missing a few things but im just lost at this point In regards to what it can be please help
So far
Air filter
Top radiator hose
Thermostat
Coolant temp sensor
Coolant temp sender
Pcv valve
Eec relay
Fuel pump relay
Wot relay
Pcm
Fuel filter
Spark plugs
Spark plug wires
O2 sensor
