Kirby N.
- February 6, 2001
- Colorado Springs, CO
- 1991 Ranger
Hey fellas-
I am working on my 1991 Ranger with a 4.0 and a manual. It runs really well and has plenty of power. The only thing is it is hard to start cold or hot. It requires some throttle and then it idles rough for a few seconds until I rev it up and clean it out. It is almost like having a carb again! If I dont give it throttle right after it starts it will run really rough and die, then start the same way again. It does start easier if I have ran it recently, but it does take more cranking and throttle even if the engine is warm. There is no CE light.
Here are some of the things I have done to try to fix it (with some research):
New Carter Fuel pump
New fuel filler neck (old one was broke and I thought it wasn't maintaining pressure in the tank)
New Spark plugs
New IAC sensor
I have a new MAF sensor to put in it but I havent put it in (thought I would see if anyone concurs before I put another $80 part in it that might not work)
New Spark plugs
New IAC sensor
