toolman4
- January 20, 2021
- Mn
- 2020 Platinum
Found the solution. If you remove the aluminum slats that are attached to the rubber strip on your rear windows (smaller quarter window seal), you’ll notice that it’s attached by double sided tape. This doesn’t bond as well to the metal as it does the rubber underside. Simply remove the aluminum strips and the double sided tape and use a little (not a lot) of goo gone. You won’t notice that they are gone and look factory but the better part is the excess wind noise goes away. Hope this helps.Checking out this forum on your issue, there don't seem to be many posts about it. One member did mention a possible seal issue in this thread, 2020 Explorer Rear Doors Wind Noise but other than that, there is very little else.
By the way, only the front side windows have acoustic glass.
Welcome to the Forum.Found the solution. If you remove the aluminum slats that are attached to the rubber strip on your rear windows (smaller quarter window seal), you’ll notice that it’s attached by double sided tape. This doesn’t bond as well to the metal as it does the rubber underside. Simply remove the aluminum strips and the double sided tape and use a little (not a lot) of goo gone. You won’t notice that they are gone and look factory but the better part is the excess wind noise goes away. Hope this helps.
Would you be willing to upload a picture or two showing this solution? I'm extremely frustrated with the 2nd row wind noise and hoping we are experiencing the same thing.Found the solution. If you remove the aluminum slats that are attached to the rubber strip on your rear windows (smaller quarter window seal), you’ll notice that it’s attached by double sided tape. This doesn’t bond as well to the metal as it does the rubber underside. Simply remove the aluminum strips and the double sided tape and use a little (not a lot) of goo gone. You won’t notice that they are gone and look factory but the better part is the excess wind noise goes away. Hope this helps.
Hey @Sgt1411 what did you do to fix your door noise?
loud rear window noise when it is rolled down...sounds like something is rapidly flapping when over 35mph. Will get family to sit in back next road trip to see if we can pinpoint the origin. Any ideas? ...will look into aluminum trim mentioned above.
As for #1, that is normal. It's called 'wind buffeting'.Not sure if its the same noise... but i've noticed two noises discussed elsewhere here before:
1. when only one window open there's the pressure "pulsing" that occurs... crack another window and it goes away.
2. I had a noise sounding like came from the window but it was a loose cover under the car... tightened that up and the noise went away.
if either of those match what you are hearing suggest looking for those discussions
Welcome to the Forum.loud rear window noise when it is rolled down...sounds like something is rapidly flapping when over 35mph. Will get family to sit in back next road trip to see if we can pinpoint the origin. Any ideas? ...will look into aluminum trim mentioned above.
"It's Caused When Two Pockets of Air Crash Together. Wind buffeting is caused by an occurrence known as Helmholtz Resonance. In a nutshell, when you open just one window in your vehicle ‒ or the sunroof or moonroof ‒ the air inside your car thumps up against the faster-moving air outside the window."
Number 1 is what is happening to me on both sides of the vehicle when I roll the back windows down. Will look for that thread.Not sure if its the same noise... but i've noticed two noises discussed elsewhere here before:
Welcome to the Forum.Number 1 is what is happening to me on both sides of the vehicle when I roll the back windows down. Will look for that thread.
is there a solution? never had this in any other car until the 2020 explorer.As for #1, that is normal. It's called 'wind buffeting'.
You could try what Spacey mentioned to see if that resolves it. I've had that same wind buffeting on many other vehicles over many years.is there a solution? never had this in any other car until the 2020 explorer.
