Since making an accurate MPG calculation would require at least a couple of tank fulls I would never attempt it since the temps far exceed specifications.Very interesting. Have you determined what your fuel economy is with no HHO and just the O2 sensor manipulation? If not, I'm not suggesting that you do with such high temperatures without the HHO.
Have you disabled your EGR?
My max amperage draw is currently 30A. I use 4 AWG wire to the generator. I use a 150A PWM to control the draw. Currently I limit the draw to 25A. In the future I will add a H.O. Alternator to the Trac so that I can efficiently increase the draw.How much current is flowing thru your HHO generator?
In my installation I used in line fuses & resettable 30A circuit breakers.Do you have a fusible link or some other current limiting device?
My installation has a scrubber with a pressure relief valve on it. I also have a flashback arrestor inline before the throttle body.Do you have a pressure relief valve?
I have documentation and the equipment I used on my Project Site It's a work in progress I am still adding to it. It consists of a site, blog & you tube. I sell nothing, this is all there just for reference. Feel free to browse.I would like to see some photos of your setup.
My original 30a PWM was a standard motor controller board. Very simple design. The board was pre etched, the components were very simple to solder in. The problem with that is I was working it at the upper range of it's operational capacity. The new unit I bought is a 150a unit. It has 3 adjusters to it; frequency, load & Duty cycle.Using a pulse width modulator to control current flow is an excellent idea. Did you design, etch and populate the printed circuit board yourself or is it a standard motor controller kit?
Not very often at all. I use KOH as an elyte. (28% mix 2lbs / 3 quarts water) I can use such a concentrated mix because of the PWM. The refill would only be distilled water. KOH remains. I am still using my original KOH mix from the bench testing My reservoir only holds 1 quart or so. The KOH flake is $7 per 2lbsHow often do you have to refill your electrolyte and how much does it cost? The electrolyte consumption should be part of the fuel cost savings analysis.
I have not installed the MAF enhancer. I use the EFIE only. The EFIE deals with the O2 sensors in closed loop mode. Once I get a definitive setting for the EFIE I may install the MAF enhancer as a sort of "fine tuner" for the EFIE settings.I experimented with altering the MAF sensor signal when I replaced my stock 55mm MAF sensor with a Lightning 90mm MAF sensor. I designed and built a three stage variable gain amplifier that allowed me to vary the signal to the PCM from lean to rich. I abandoned the idea for two reasons. The first was that even using temperature compensation I could not achieve gain stability over the large temperature range in the engine compartment. I had to keep adjusting the pod mounted gain control. The second and more significant reason was that I learned the amplifier only affected the A/F ratio when the PCM was running open loop. As soon as the PCM switched to closed loop the O2 sensor signal to the PCM determined the A/F ratio. Have you determined the actual impact of your MAF enhancer?
What impact (if any) does the hydrogen have on the engine performance during open loop? Does your vehicle accelerate as well as normal at moderate to full throttle? If not, have you considered automatic deactivation or would the response time be too slow?
I purchased a dual EFIE to handle the upstream sensors only, but in retrospect I feel a quad would do better so that I can adjust the signal from the downstream after the cat.I've considered purchasing an EFIE to experiment with but I couldn't find one that meets my requirements. I want one that has adjustable offset and gain. The PCM in closed loop cycles the A/F ratio between about 5% rich and 5% lean. If the O2 sensor signal was amplified then the variation could be reduced without the PCM realizing it.
My induction point is way after my MAF sensor on my intake just before the throttle body. refer to the video I recently uploaded to You Tube titled "The Installation Results"Where is the hydrogen introduced into the induction system? Is it after the MAF sensor like EGR?
Not really monitored yet, I did do a quick read & it looked normal.Have you monitored your ignition timing to see if it is typical?
What fuel economy improvements have you measured and for how many tanks of fuel?
In open loop the truck ignores the manipulated O2 signals and defers to the presets in the ECU. Acceleration is normal, and throttle response is normal.
I considered the above scenario when installing, so I did include a manual activation switch so the system could remain off if open loop operation was hindered. It has not been. Normally I leave the switch on since the system self activates when the ignition is on only.
I saw & felt no significant change when introducing the H2. Acceleration remained the same.I was referring to the H2 introduction not the EFIE altering. Have you performed any acceleration tests with and without H2?
That was what my research indicated as well that the downstream O2 sensor was only reporting results but did not influence the ECU. Once I have my optimal EFIE setting, I would experiment further to see if tweaking the downstream has any benefit.I see no need to modify the post-cat O2 sensor signal. The PCM only monitors the output to determine if the cats are functional. According to Ford the post-cat O2 sensors have very limited effect on the fuel trims. Adding a bias to the pre-cat O2 sensor signal should not significantly impact the post-cat sensor based results.
That means the introduced H2 is not metered by the PCM. The volume is probably so small that it would only affect the idle. The IAC valve would easily compensate.
I would data log the ignition timing with and without HHO and compare the results. Your knock sensor could be detecting detonation and retarding the timing. You'll get the best performance (fuel economy and acceleration) with the timing advanced to just prior to detonation. If the knock sensor detects detonation the PCM will immediately retard the timing a large amount and then gradually advance the timing in very small amounts.
Please post your fuel economy results after several tank fulls of driving.
. . . Correct. I am only pumping 2 liters per minute of H2.
About 55 years ago when I was a kid I experimented with electrolysis. I collected the oxygen at one electrode and the hydrogen at the other. If the two gases were allowed to combine in the pressure of a spark they would recombine with water and heat as byproducts. If you use KOH as your electrolyte isn't oxygen being generated also? Aren't both gases mixed in your cell? Isn't there the possibility of an explosion?
Does your scanner have the ability to data log the "knock sensor retard" parameter? When I was doing my WOT test runs for my custom tune my knock sensor retard would jump from +0.25 to -8.0 due to the knock sensor detecting my timing chain rattle. Jame Henson of Henson Performance provide me a tune with the knock sensor retard disabled so he could complete the tuning. I had to watch the A/F ratio during the test runs to make sure it didn't suddenly go lean. When I finish installing my engine with the repaired/replaced timing chain components I'll enable the knock sensor retard.
P.S. I saw your Jaguar in the video. I've owned an XK-150, E-type, MK-II and XJ-6. I really enjoyed the torque of the inline DOHC six. I considered purchasing an XK8 to experiment with but will probably settle for a Mustang GT.
