devi59
- March 14, 2009
- Belle Fourche, SD
- 1993 Eddie Bauer Edition
Bought an explorer this january used. its a 1993 eddie bauer edition. it ran great for awhile. unfortunately ran into a buttload of problems. First was losing heat during a bad blizzard season. replacing the heater core (of course after changing the coolant and having the water pump removed and checked) and it worked like a champ again. then I lost my drivers side window, it wont go up or down unless i move it manually (which is probably that white bushing thing i read about here). 4x4 stopped working (assuming it is stuck between the 2, the computer seems to be clicking but i dont think the motor is working).
All this pales in comparison to what is happening now.
It won't start. it has some aftermarket anti-theft thing on it. tried replacing the battery (walmart said the battery was fine, but its walmart so i didnt believe them and i bought a battery 2 days later). This got it started, i took to the gas station to get it filled up. Tried to start it up, same clicking noise, not starting, alarm going all crazy like its not getting enough juice. tried to jump it but it didn't help any, so now my car is stuck at the gas station and will probably get towed in a day or two. I noticed when replacing the battery that the positive had an extra wire to it (probably to the anti-theft thing) and the entire main wire is really corroded. I cleaned the terminals and figured that would have done it, but nothing worked. im really worried after reading many horror stories here so I really need some help. anyone have a clue what the problem is? i don't know really anything about a vehicle. i know how they work (i took a small motor class in highschool) but I get really nervous under the hood, especially when dealing with electrical. Anyone got ideas? I will note this, I am basically dead broke.
