hay everyone..im new..also got a question. | Ford Explorer Forums - Serious Explorations
nicklux
perth
2003 ux limited explorer
im from australia,so we may call our cars different names..
I have a ux explorer limited.
i have just removed the rear right hub (plus brake kit and all) cause the hub studs (wheel bolts) are thrashed out,ive got all the new hub and hub bearing kit to go in but CAN not get the old bearing and hub off the brake asembly DO i have to get this old hub and bearing pressed out with a bearing press and the new one pressed in or is there another way around this seeing as i have no car to get to a mechanic..
thanks guys..
ANY help would be amazing thank you..
if the bearing is good have new wheel studs pressed into the old flange,,
